Worth upgrading?
6 May 2009
I currently have:
Gigabyte P55-UD5 motherboard
8gb Kingston HyperX Genesis DDR3 1600MHz
i5 760 @ 4ghzArctic Freezer Pro 7 Rev 2
Do you think it is worth selling these parts and upgrading for hopefully only a small cost? I think I would benefit from SATA3 as I have a Crucial M4 SSD but not too sure what the other gains would be.
The last kit I sold was a q6600, ran and motherboard then got the above 2nd hand which ended up costing me about £20
What do you use the system for?
In terms of performance you would not notice any real difference from a SATA 2 to 3 board.
If needed get a first gen i7 and slot it in, job done. It's not worth selling the lot and getting a Haswell system for the performance benefits.
Wait for next generation broadwell, probably about jan 2015
imo there's no point in upgrading on the cusp of when haswell becomes obsolete...
I find it never works if you wait for new stuff to release - if you do that, you will endlessly be waiting for a new thing to come out once you've waited for one thing, it just becomes a cycle. Buy whenever you need an upgrade, not want an upgrade imo
There is a difference. In my work place there are both sets
sata 3 doesn;t even finish 3 secs of the windows symbol on boot up but sata 2 finishes it...
it gets me every time because it looks like a crash but it boots so fast, i look down at my shoe lases then poof its at desktop...
true but not if you are of the mindset that you're keeping the comp for 4-8 years...
Thanks. So its either;
wait for next gen (prices of 2nd hand will drop) however i could keep waiting forever
Drop in an i7 cpu - which one will clock to 4ghz+ ?
Or upgrade and get sataIII because its fast, totally new cpu, board & ram
