i went from a 7950 boost oc to a 7970 to a g1 970 gtx. the difference is very noticeable. in some games close to twice as fast.
only downside i don't like the nvidia image quality compared to amd. everything else is very good.
a 970 gtx is faster than a 290 and 290x unless its at 4k. then its a couple of fps difference. thing is none of those cards are for 4k alone. so pointless.
All cards out at the minute are pretty much equal depending on the games you play. Yes the amd ones do run hotter, use a tad more power. But, is the average gamer going to notice a big difference on screen in the games he plays, (most of which now are poorly coded ****). Sure benchers will notice the difference, but theyre in the minority of the high end card users who are a minority themselves.
?Bit obvious, the 290's have unlocked voltage control. On nvidia cards you have to mess about with custom bios revisions to allow for overvolting. This isnt for everyone. As mentioned, the power use and heat generated by amd cards is off putting for some. Myself, im not fussed on power use, (this isnt the greenpeace forums) but the associated heat can bump up the temps of other components.And between the 970 and 290s, which one would the benchers prefer?
Tbh Boom, i have no real need to upgrade myself. But you know the old itch when you have a few quid spare. Heck earlier this evening i had the guts of an X99 setup in an ocuk order basket. Thing is too, the 4790k in sig is going great, bit of a mild oc of 4.7 on it. Reckon it could do a bit more. Sometimes i just splash the cash on crazy upgrades, either that or blow the money on the horses.Just wait a bit longer imho, if you have come this far without an upgrade a couple more months should be easy. With new cards coming (Hopefully soon) they might be worth the wait or if not for those cards prices on current cards could be adjusted, so might be a better time to upgrade.
Sorry for hijacking this thread but i'm in the same boat!
I have a GTX680 currently, would i get away with a GTX980 with current spec in sig?
Id definitely upgrade CPU
