guest
guest
Hi guys,
I run a Zotac GTX 670 OC in the system on my sig. No overclocking on the CPU or Card (apart from the factory OC on the 670).
When running games my card maxes out at 80-85C which I know won't kill it however am I losing performance by letting it get up this high? I'm worried it may be thermo throttling. No issues in games but I just want to make sure I'm getting the most of my kit. At 85C the fan probably only hits around 55-60%.
If I do want to run a custom fan curve what is the best software to use? Is there any way for me to see what fan curve my card is using by default?
If it's fine to use at these temps with no issues I'd rather not increase the fan curve as the noise level is at a decent level at the moment.
Thanks
P.s the CPU and system is running fairly cool so case cooling isn't an issue.
Overclocking is a free upgrade and should be compulsory though![]()
Surely better to adjust the fan curve using MSI AB before even thinking about replacing the cooler varkanoid!! Perhaps just an extra 10% increase in fan speed could reduce temps significantly without the problems/cost of changing cooler.
I only game with headphones on so a loud fan under load doesnt really bother me, as the OP mentioned, better to keep temps down to avoid throttling.
