Hi there. Having had my Antec Plusview 1000 case for well over 4 years (maybe longer) i fancy a bit of a change. This is down to 2 reasons, the first being i just want something new, as have upgraded the bits inside twice without changing the case.
The second reason and probably most important is the noise factor. Only being able to have 80mm fans is a bit of a pain so would like to be able to have good cooling but without the noise to go with it.
This is my current set up:
Now i have been looking around for a little while at what case to replace it with and i have seen the Thermaltake VA7000WA Shark. After checking the dimensions it will be slightly bigger (which it doesnt really need to be as the Antec is already pretty big) but is a bonus, and also the 120mm fans is what i am looking for.
Any comments are welcome regarding whether this would be a beneficial upgrade, or any suggestions on what case other than the Shark to get. Price wise i dont really want to be spending any more than about £85 really.
Thanks for reading.
Thanks for reading.
