Worthwhile Upgrade (3770)??
18 Jan 2006
Norwich
With the current Black Friday prices, I'm actually seriously considering an upgrade here, and would be very interested in anyone with thoughts, positive or negative :P
Current setup is a 3770 (non-K), Asrock Z75 board 32gb of RAM & a GTX1060.
Some gaming use (RPGs, train / flight sim), but primarily programming in Visual Studio.
I've priced up a basic upgrade with the following:
  • Ryzen 2700
  • Asrock B450 ATX
  • 32gb (2x 16GB) of Corsair DDR4
This comes to just over £350, and I can't decide whether to pull the trigger or not :P
My biggest niggle with the current setup is that when working with a massive solution and Resharper, Visual Studio can be laggy as anything.
I believe this is limited by 2 primary factors- Disk IO and single core performance, neither of which this will really help too much (about 10% increase in single core, corresponding memory bandwidth increase also helping?)
On the flip side, Ryzen would allow me to stuff a NVME drive in and massively increase the disk IO, and Resharper will take advantage of the extra cores to some extent.
You've answered your own question. Your current system is "laggy as anything". So upgrade.
Not sure about the ASrock B450 though. I'd buy the MSI B450 Tomahawk Max.
I wouldn't spend more than £140 on a 2700 though.
I'd go with a Ryzen 3000 series CPU and get some B-die high frequency dual channel DDR4 RAM. Ryzen 3000 runs higher frequency RAM easier than 2000 series.
Ryzen 3000 will be better but as a question of cost, paying around £300 for a 2700X, Mobo and 32GB RAM for a barebones upgrade is pretty compelling.
This is hard :P
Halfway considering waiting to see what we get on the 3800X as Gibbo has hinted, but even with a decent (20% ???) cut, that still rams up the budget massively.
This is hard :p
RRP for 3800X was £380 on release so they are well below RRP currently and moreso come friday. How much is anyone's guess. 3700X is below RRP too, they were £319 on release.
Choices, choices!
Don't get a Ryzen 2700 - that's the last generation; get a Ryzen 3600 or 3700. And the motherboard of choice is the MSI Tomahawk MAX.
I guess we need to see what happens in price on the 2700 and 3600 but there could be quite a gap in budget between those two options.
I can't see the 3800X ever making sense though.
