Would a 4k monitor be clearer? 32"
19 Oct 2002
I have a ASUS TUF Gaming 32" 2K HD Gaming Monitor (VG32AQ) - QHD (2560 x 1440), 165Hz (Supports 144Hz), 1ms, Extreme Low Motion Blur, Speaker, G-SYNC Compatible, VESA Mountable, DisplayPort, HDMI ,Black. I am wondering how color ac orate is it? A youtube vid. says the 27" inch is the best budget gaming monitor
4K will get you better image, if that's what you mean. Whether it is worth the extra money for you is a different matter.
I find a monitor to be very subjective.
I have a 2k - 32" Ultra Wide Screen and it's good for gaming etc but I also use it for work as well which works great.
Picture quality is really good as well.
I would suggest shopping around and find something you like.
I have this one in my rain forest cart now,LG UltraGear UHD 32-Inch Gaming Monitor 32GQ950-B, Nano IPS 1ms (GtG) with ATW, VESA DisplayHDR 1000, NVIDIA G-SYNC, and AMD FreeSync, 144Hz, Black. Ny card is not enough though, waiting to see if Intel Battlenage will be worth it. Nvidea are some monwy hungery little jerks. Over here the prices are high anyway. Good to have a new GPU maker who doesn't want your first born for a card.
It's High-Hz 4k man, you got what you deserved!!! ;) :D
Still v v harsh on graphics cards as you know, hell I drop down to 3840x1600 Ultrawide on my 42 usually to get high/er fps.
Ive an older 144hz Benq 27 1440p monitor and I've managed to scratch the screen and its annoying to spot.
I fancy a 32inch 4k, but currently dont have enough ummph for higher fps 4k. But would like to future proof, how bad would 1440p look on a 32 4k until I upgrade in a year or two ?
It’d look similar to running 1920x1080 on your 1440p monitor at the moment.
Kind of depends on the game as well… but I regularly run 1440 on a 4k tv and think it’s fine for gaming
