Would a change of router help?
Permabanned
18 Oct 2002
Stoke on Trent
i am on a BT line and my ISP is tiscali
i have a thomson TG585 v7 router, but i am getting really rubbish speeds.
tiscali have said the usual things like i should get upto 8mb but i am getting from 1mb to 2mb
i was thinking of buying either the Belkin F5D8631UK4A, or the Netgear DGN2000, or am i wasting my money.
is it all down to settings or something
this is what my router tells me, so if you can shed any light on this for me please...
Link Information
Uptime: 0 days, 2:01:54
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,384
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 27.5 / 48.0
SN Margin (Up/Down) [dB]: 18.0 / 9.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 97 / 0
Loss of Signal (Local/Remote): 62 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 127 / 0
FEC Errors (Up/Down): 0 / 4,638
CRC Errors (Up/Down): 0 / 8
HEC Errors (Up/Down): 0 / 8
i cant get 02 here where i live, and i have only just entered a 12 month contract with tiscali (10 months to go) i know my router says it has a down speed of 4.384 but i am getting nowhere near that, do you think it might be the router settings, someone mentioned about altering the MTU size also, but i dont know how to do it
No, the problem is most likely Tiscali. MTU tweaking is largely pointless these days, except for a few weird ISPs (CPWH/AOL use 1400 bytes).
