Hi,
My friends laptop (Acer Aspire 5100) recently stopped working.... well, it powers up but the nothing appears on the monitor. I have tried connecting it to another screen but the same thing happens.
Took it apart today to look for the battery in the hope that i could reset the bios or take the battery out to see if that would help, but the battery is soldered on and i tried touching both connectors to the battery with a screwdriver to reset it but no luck.
Also took most of the components out (memory, hdd, wireless adapter etc), but that didnt help either.
Found the service manual earlier and it says this:
No beep, power-on indicator
turns on and LCD is blank.
Power source (battery pack and power adapter). See
Power System Check.
Reconnect the LCD connector.
Hard disk drive
LCD inverter ID
LCD cable
LCD Inverter
LCD
System board
So im kind of assuming the RTC battery isn't the cause, but just wanted to check.
Cheers
Power System Check.
Hard disk drive
LCD inverter ID
LCD cable
LCD Inverter
LCD
System board
Cheers
