Would a glasses lens cloth be ok for cleaning a PJ lens?
14 Aug 2003
cyberspace
Just wondering would a glasses lens cloth be ok for cleaning a PJ lens?
Sorry for asking a stupid question,but I'm worried about damaging the lens.
Why do you need to clean it? How did it get dirty?
Usually a can of compressed air is all that is needed.
highly unlikely surace dirt on the lens will cause image problems, unless you can see it on the projected image dont touch it.
Tattooed said:
hi,
Thanks for the replies. The lens is not really dirty, it just has some dust on it.
If you cannot see it on the projected image then do not touch it.
Otherwise use compressed air. Make sure you use it correctly otherwise moisture will spray everywhere.
