Would a mini-itx system be suitable for...
7 Mar 2005
The Voice Of Football
A basic HTPC?
I want something for the lounge that I can use as:
A PVR using a TV card for freeview
Playback MP3/DIVX etc
Playback Blu Ray
Basic surfing the net and emails etc
The other requirement is a nice case and silence!
depends on the setup really.
you can get mini itx systems with Via's C7 cpu (which are abit slow) or ones for Intel's Pentium m's or even duos now.
I've been using a commell lv-671 mobo for about 3 years now for my media (admittedly without any tv card) and it works a treat
Would work fine just make sure the processor you get is quick enough for HD playback (If required) because of the size of them you may have to have external Blu Ray and freeview stick
cheers for the spec gt...how much am i looking for that price wise?
Getting the case is the difficulty as that hoojum's as rare as hens teeth - however, i'm sure you'd find a decent alternative. :D
All the other components would cost between £250 and £300 for the cpu, mobo, ram, hdd and optical drive. Getting something like an e5200 and a touch less ram will lower costs - also, getting stuff 2nd hand will help too.
Last thing to say is make sure that the PSU can cope. The pico psu i use is rated at 120w with a power brick that in turn is rated at 102w. Runs perfectly - is cool running and most importantly silent! :)
gt
