2 Aug 2006 at 15:46 #1 SameSuspect SameSuspect Permabanned Joined 7 Jul 2005 Posts 710 Location Suffolk i got a logitech g5, which is hard to use at the mo because the lead isnt long enough, would buying a female to male extension for it affect it at all
2 Aug 2006 at 16:41 #2 Tetras Tetras Man of Honour Joined 22 Jun 2006 Posts 17,264 Should work fine, just make sure you buy an A-A USB lead and not an A-B
2 Aug 2006 at 16:42 #3 killer_uk killer_uk Soldato Joined 12 Mar 2003 Posts 4,068 Location OcUK HQ As Tetras said, it should work fine.
2 Aug 2006 at 18:46 #4 SameSuspect SameSuspect Permabanned OP Joined 7 Jul 2005 Posts 710 Location Suffolk didnt think so, just thought id check.
