im looking to upgrade my pc i did intend on buyin a pc on the 25th of last month but my bike engine blew so that got priority.
my current spec
amd sempron64 3100 sct754 (oc 2.17ghz)
gigabyte k8ns pro
kingston value 1.5gb 400mhz ddr
gforce 6600le
soundbaster fatiality extreme gamer
2x 80gb sataI wd 8m cache (raid0 atm)
corsair 620w (just got this as start of upgrade
2x 520gb sataII WD 16mb cache (will raid0 these for new system) (also just got for upgrade)
Antec ninehundred case (just got for upgrade)
DVD RW lg 18x (just got for upgrade as its black)
IDE 80gb WD 7200 (use as safe storage for important things)
what i want to end up with is
c2d e6600
2gb corsair dominator
8800gtx oc 768 (maybe sli later)
bfg 680i
dvdrw from above
hhd's from above (will i be able to set up 2 sata0 arrays?)
the asrock for the stepping stone will be
Asrock 775DUAL-VSTA Socket 775 Motherboard
i will change this as soon as i have all the other components
my current spec
gigabyte k8ns pro
gforce 6600le
c2d e6600
bfg 680i
dvdrw from above
