Would anyone be willing to cut my case in Sheffield?
25 Apr 2004
Devon
I'm just wondering if a forum member might be able to do me a massive favour. Basically I want to watercool my P182, but I lack the necessary tools and experience to cut it properly without messing it up.
I want to mount a dual rad on the top and so I need a hole cut for an extra 120mm fan - the case already has one 120mm fan in the top. I'd need a couple of smaller holes for tubing too.
Like this: http://forums.overclockers.co.uk/showthread.php?t=17643648&highlight=watercooled+p180
but a dual rad.
Obviously I'd get it all marked out and ready before hand, I just need some help with the actual cutting.
I live in Sheffield, I don't have a car but could get taxi/bus etc. I can't afford to pay a lot but I'm sure I could give a bit to anyone willing to help me out! Enough for a few drinks at least :) I'd really appreciate it as I have no tools whatsoever, and I've tried cutting a case before with a jigsaw and it didn't go very well!
Alternatively, can anyone suggest someone who would do this kind of work and cheaply in Sheffield?
Cheers,
Felix
Sorry for slow reply! Yes I am still after help! Rad and things should be arriving tomorrow as it happens :) Still need to buy some tubing/barbs and distilled water or coolant or whatever I should be putting in it!
just saw your edit - Will add you to msn in a sec then
cheers,
felix
try and get hold of feser1 its about £8 a tub and its uv reactive also non conductive with all the addatives needed for your loop
Thanks for that, I may go with MCT-5 tho tbh as I want to buy all my tubing/clamps etc from one place for ease and to cut down on delivery charges. Online store I'm looking at has MCT-5 or 40 or that smoothy water stuff.
will 945ml be enough to fill my loop?
Dual rad, res, pump, cpu block and tygon 1/2" tubing..
Felix
fesser 1 usually comes in 1 ltr and is usually not enough for a single loop, especially if leaks show up, so it would be best to get 2 945ml bottles
Thanks for replies people, and thank you so much for the offer of help Ichabod!
I've actually decided to go with a Mozart TX case now as it will allow me to do everything internally, I just love the hugeness of it - it's like a desk extension!
Cheers,
Felix
