- 7 Jan 2003
- Leicester
in terms of image quality would better lenses be the way to go or would the 300d body be limiting?
thanks
thanks
Whilst I agree with Ksanti about the size issue,
I don't when it comes to the quality of the 40D. There's nothing wrong with the quality of the images produced by the 40D. The 10mp resolution may seem a bit low these days and will limit the ability to crop heavily but the images produced are still fantastic and in some cases better than those from the 18mp sensor in the more recent models, especially when it comes to noise.
thanks Ksanti,would the fact I'm using auto be anything to do with it,should i set the camera manually to get the best shots?
Im happy to make both changes if it will be an improvement
thanks
I can't personally give any experience of either the 550D or 40D's image quality, I'm just going off the experience of seeing lots of people posting on forums wanting to move on from the 40D because of the high-ISO performance. That said I just looked up the dxomark data and there's not that much in it between the 40D's 10MP sensor and the 550d/600d/60d/7d's 18MP sensors, but then there aren't any better Canon crop cameras (just yet, that'll change soon) in terms of sensors than the 18MP ones, short of the 1D ASP-H crop ones.
I'd sell all my lenses except the 501.8 and 300d, and get a 5d mki
It would be like having a 35mm F1.1 on your 300D, ISO will be much better as well...
Depends if he uses anything other than the midrange of his 18-55 tbh, as a 5D and a 50, while a lovely setup (I shot nothing but a 50 1.4 for the first few months of having a 5D), leaves a lot of gaps to fill that can be quite expensive.
I see you guys only use primes.i must admit the 50mm is on for the majority of time, so tomorrow i will buy either the 5D mk1 S/H or a new 550D? so what should i do ?![]()
would it be noticeably different on a 27 IMac or is it only when you print larger sizes?
A local camera store has a second hand excellent con 5d mark1 for £700
Nope. Only on print. The Imac is 2560*1600 yes? The images are all bigger than that.
