Would h50 fit in this case?
16 Dec 2009
I am wondering if the h50 would fit in this?
I have used this case before and think would maybe fit, anyone tried?
I thought about where that 120mm fan is the only reason why the radaitor wouldnt fit is because that bar thats there. if i could possible attach the radiator without the screws it would work but yeh
I have one of those cases lying around and i don't believe that the H50 would fit. Space is pretty tight around that fan and the rad is bigger than the fan. That case does get rather hot as well.
Air coolers sre severely limited in height due to the construction of the case and airflow is poor anyway. This is the main reason i stopped using mine.
can you measure how big the cpu cooler could be please? lol ive only ever had the stock cpu cooler on. i know its restricted by the back panel height, is it possible to install one once the motherboard is put in?
The cooler has to be installed before the motherboard tray is slid in otherwise there is no chance of getting one in the case let alone fitted. The stock Intel and AMD coolers are the biggest that will fit that case due to the divider between the top and bottom sections.
It isn't the size of the cpu cooler you have to worry about, it's the radiator.
It's at least a cm or so bigger at the top & bottom of a 120mm fan, and by the looks of that case, it won't fit.
