Would i benefit from a better motherboard
13 Mar 2017
Leicester
Hi guys, I'm currently running a 3800x on a MSI x470 gaming plus mb and cooled with a Corsair H80i.
My question is, my processor doesn't really go above 4.1Ghz even in the most demanding of tasks. Would I see a performance increase in getting an x570 board? I'm looking at the x570 taichi. I'm also looking at Ryzen 3 in the future and I hear there won't be an x670 until zen3+
The cost is just not worth it for little performance if any gain.
While not great board, its VRM is enough to not limit stock CPUs.
(unless you have some very hot case)
As above make sure your case is well ventilated. Make sure you cpu temps are not getting near 75c. Make sure you are on the latest bios anecdotes AMD chipset driver. Make sure you are running the AMD high performance power plan.
