Would I notice a difference?
15 Aug 2003
Staffs
I have been thinking of upgrading my CPU for ages now as the current one is probably the longest I have ever kept the same CPU!
I have an original Conroe (can't remember the model but stock is 2.66Ghz) running at 3.2GHz. Would I see a big difference in upgrading to a Wolfdale 3.16 with the extra cache or am I wasting my cash?
yes, but only in benchies
A quad is the only sensible upgrade from an E6700 tbh.
if you spend more than 125 pounds (price of OEM Q6600), and dont get a quad core, your either, 1) insane, 2) serious over clocker who does it for the sake of it.
also, if you buy a Q6700 over the Q6600 your totally insane
basically make sure its a quad core and not pre-overclocked
What is the spec of the rest of your system?
Asus P5B with latest bios, 2Gb corsair, 8800GTX.
My other question was going to be about the best ram for a quad core if I'm not overclocking and want 4Gb.
I just can't beleive how long I've had the same CPU....I used to change them at least twice a year!
Well there's certainly going to be price drops in the next couple of months.
But so far they've only been confirmed as happening in Q3, and that's any time between 1st July and 30th September.
oh right... that is actually quite a longer time than i thought... in think i may get impatient myself in that time :-)
Might be worth waiting a week or so as there might be a definite date by then be it the 1st July or later. Then decide from there.
