- 19 Jan 2010
- Merseyside
Hi, at the moment my setup is whats in my sig, but i have already decided with the lack of space inside my storm scout case that i am going to change to a Silverstone RV02 Raven 2 as it will greatly improve my airflow, with the h50 installed the pipes bent right out so i cant install fans on the side window on my current case.
After changing my case i want to switch to air cooling, specifically to the Noctua NH-D14, at the moment im using the h50 in push pull and 1 intake and 1 top exhaust fan, idle temps around 33c with fan and pump on 100%, do you think i will see much of a change in temps if i changed the case and cpu cooler to the ones stated?
Edit: i will be selling the case and cpu cooler to cut the cost of the new bits so it doesnt hurt as much aswell.
