Would it improve quality?
17 Sep 2012
Scotland
Hey guys, was just wondering.
I have Creative Fatal1ty MK I headset, was wondering if a soundcard would actually improve the quality?
ive never bought one before so was just hoping for some advice.
Cheers.
Yes, yes it would.
Do you use it for mainly gaming, music, films or all of the above?
What is your budget.
http://www.overclockers.co.uk/showproduct.php?prodid=SC-015-AS&groupid=701&catid=11&subcat=
That is a good entry level soundcard.
Has an inbuilt headphone amp too which is handy.
A good way to dip your toes into better audio.
Shudders at the thought of going back to onboard audio.
I'd use it primarily for gaming, but listen to music also :)
My budget is around 60-70 pound.
But I'll buy that one for now, to try out :)
I wouldn't expect night and day changes with a cheapish headset but it certainly wouldn't get any worse hehe :)
Yeah that soundcard seems fine and then possible save up for some decent headphones if you find you're still looking for better sound
As above, as DGX would be a worthwhile upgrade over the onboard audio you have, I'd imagine. I don't really know how good VIA's onboard audio solutions are. I wouldn't expect they are as good as Realtek's better offerings.
Ultimately though, it's down to the user. People have different experiences. Some find a dedicated sound card better than any onboard audio, while others find onboard just as good a dedicated sound card, except the high end ones.
Given your budget, a Xonar DX would be a very good purchase. It's a great sound card. However, given your current headset, it's rather pointless spending £60 on a sound card for use with a £30 headset. The headset or headphones play a larger part in the overall sound quality than a sound card upgrade will. £60 headset and a £30 sound card theoretically would provide better sound quality than £60 sound card and £30 headset.
There are two ways to look at it. You could either get a DGX to match your current headset, or you could spend £60 and get a DX, then upgrade the headset at a later date. If you have no intention of getting a "better" headset, then I'd just go with a DGX.
Hmm I'm not sure what to do, maybe just get a better headset now? Then at a later date get the DX?
Not entirely sure you'll get a much better headset with noticeable improvements unless you go a bit higher with the budget but others might be able to help.
The DGX seems like a good start and then save up a little for a better headset or headphones + external mic which seems to be better value for money when sound quality is the main aim.
Out of the cards mentioned if I worried only about headphone as opposed to speakers I would simply go for the DG or DGX (PCI-e). Note that if you want a built-in headphone-gain amplifier the DX does not provide this.
Yeah I meant DGX :P Something with a built-in amp :)
