Would like a Home NAS System spec'd
24 Mar 2004
Hi guys
Would like some specs put forward for a home NAS system.
Only needing the box as i have spare port on the KVM
A few things that i think i need (but maybe not!)
case with the ability to add fans to blow cold air over the drives (this is very important)
loads of bays for hard drives
raid 5
gigabit connections
blu ray burner
no real vga power needed
with regards to the OS i'm pretty much a XP person so have no experience of other solutions, however with this project i understand that to get the best out of the box i will need to expand my horizons so would be looking for some suggestions on the best way forward
Thanks
Blu-Ray burner on a NAS box :confused:
openfiler is the best (free) NAS environment I've used, but it would render your Blu-Ray burner utterly useless.
My solution is probably a bit low-end for what you're looking for but I have an old shuttle (easily available on ebay) with a SATA controller and 2TB. It's just an old 2.8 celeron but for what I use it for it does everything I need.
Something like that you could fairly easily put a Blu-ray burner in and gigabit ethernet if it didnt already have it.
I use ubuntu desktop edition (server lacks a GUI) and find it runs everything a lot smoother on low-end hardware. I run ftp, smb, torrents and various other services off the box and have not ever had any problems with it.
The only problem with that is that with a shuttle case you don't get any room for extra fans etc, why are these so important to your build?
Would like the ability to back up and store off site and i figured that blu ray would make that the easiest with the amount of data a disk can hold.
For that I would have thought esata would have been a better choice for quick, offsite backup. E-sata caddy's are pretty cheap these days and you would probably cover the cost after a few backups not using discs (depending on how much data you're going for)
Seems like a good setup but from past experience with hard drive failures it is very important to have a cold air flow going over them to prolong life. I have had 2 drives fail on me in my life which i believe was to overheating in a small case. Since then i have always made the point of having cases with fans blowing air over the drives and never had a failure since.
I like this idea...thanks!
External hdd's are more expensive, harder to cool, slower to access and harder to set up with whatever network storage method you're using.
I have had about 15-20 HDD's over the last 8 years or so and though I have retired a few because they were 3+ years old I have never had one die on me to the point where I have lost data. I would personally just go with a brand of drive I trust. Never had a problem with Seagate, WD or Maxtor myself.
How much data are you going to be backing up?
