Should be possible. You'll just need an internal or external USB capture card to plug the video/audio channels from the wii into and then add the capture cards stream as a source on obs on the pc. Much like when twitch streamers have a separate streaming pc.
The capture device depends on what a/v out is on the wii. I guess component/scart with a video channel and l/r audio?
