would missing cpu pins affect boot up
5 May 2004
hi all
well i took my comp apart cleaned put back and then it gave me the errors for dram error in dual channel mode never did this before
thought it was a mobo fault got new mobo and when installing dropped processor bent a load of pins and i think maybe snapped 2
my question is
if i had snapped these 2 pins before i dropped the processer and put back in my old mobo which did work fine would this affect the boot up and seeing of the ram
it worked fine in single channel mode in banks 1 and 3 but would see no ram at all in banks 2 and 4 in any combo
just i cant be bothered to redo just to test
do i sned this back to ocuk or not
You can't just send it back because you clumsied the processor. And yes, 2 broke pins would screw it up, you're lucky it runs at all.
How someone can drop something so small that costs so much which is also so fragile is beyond me... :rolleyes:
Indeed two snapped pins can affect boot up...If the pins are bent then try and straighten em we gets processors like that at work sometimes.
Dont quite get why it works in single channel but not in dual channel tho...
There is a little trick with some wire for missing pins, that I've used with some success. Get a lillte bit of thin gauge, but stiff wire. I use resistor offcuts. Cut it to length, just so that it's proud of the socket surface, only a gnats, works better if the end is flat. Clippers will pinch the end. Push the CPU down hard, if your lucky you may get away with it. Don't forget they're in there !!
hey colin it happens
you never make a mistake
it has to be mobo has i got new one and ram is fine it was just 2 pins broke off not bent then it would not boot in dual chanell but fine in single channel
new mobo with processer works great with everything else i just asked if it was worth re fitting old mobo with new processor to see if it boots as i cannot see how 2 broke pins would cause it not to boot up in dual channel but allow single channel
chill out colin, he came here asking for help not a lecture.. imagine how youd feel if you bent your pins :rolleyes:
ive heard stories of people taking cpus with bent/snapped pins to a jeweller for repair.. sort of sounds like an urban myth to me but it could be worth looking into! ;)
im not bothered about the pins on old proccy thats now in the bin and i have a new one
what my main question is is should i check it out with my old mobo that needs to go for rma first or dont you think it could have been the broke pins that caused the ram faults on boot up as it was fine
i dont really want to mess about re fitting again when my new mobo is in already and running fine
i cant see how 2 broke pins would affect it like said it wouldnt have booted
so has to be mobo
Don't bin it - put it in MM or on the 'bay. Someone will take a punt on it, especially as it boots up - even if only in single channel mode.
This could be a daft/insulting question, but the old motherboard was a dual channel board and/or you had the RAM in the right slots for dual channel?
Depending on what processor it is, they have lots of 'spare' pins. I'm told that on a S478 processor only about 100 of them do anything 'individual' - all the others are duplicates of other pins.
oh yeah they were bust alright
there was a total of 3 pins broke on one side and about 8 really bent over
mobo was a gigabyte k8n sli mobo
it was all running fine i took apart to give a good clean and when i put back together then that when it wouldnt boot in dual channel
hence i got a new mobo and when fitting the proccy to this thats when i dropped it and had to get a new one for new mobo
hence my question what if i broke a couple of pins without realising whilst cleaning and then putting back in the giga board would it have booted up in single channel
only reason now is do i retry the new proccy in old giga before i rma it DO U THINK A COUPLE OF MISSING PINS WOULD ALLOW IT STILL TO BOOT BUT ONLY SINGLE CHANNEL
the old proccy really wound me up so just for the fun of it i took a great whacking screwdriver and bent every pin on there just to show it whos boss lol
I'm not sure why you removed the CPU for cleaning, you should have left it locked in the socket. I know that's besides the point, but it might be useful to remember that in the future. :)
bigjonnyauk said:
not really my temps were going a bit higher than norm so wanted to reseat and re goop it
The thermal paste can be cleaned off with the CPU locked in the socket. It's not possible to "reseat" a CPU as it's a guaranteed fit, but yes you can reseat a heatsink. I would personally have removed the heatsink, cleaned off the thermal paste (leaving the CPU in the socket), apply the new thermal paste and then reseat the heatsink. Maybe it's just me being too cautious, but I never remove the CPU from the socket unless upgrading.
