- 18 Feb 2009
- Behind you
so, yeah, im using autodesk inventor 2008 at work with an assembly comprising of 600+ parts, and like i said, its woefully inadequate. Has a habit of taking 20 mins to open the file and then CTD every once in a while if i overload it (which isnt that hard). The IT people have suggested just shove some more RAM in. While i can see the program is a memory hog, its also a processor and GPU hog as well. So, question is, how much help would some extra RAM be?
tis a dell Optiplex 755
core 2 e6550 2.33ghz
2gb ddr2 677mhz ram
intel gma 3100 (yes ... i know...)
I think the max for the dell is 4gb, but it could be 8.
I ask this because if the ram doesnt really help i might be able to argue the case for a workstation...
2gb ddr2 677mhz ram
