Would one pump be enough?
Yeah I run 2 480 mm rads, cpu and 2 MOBO blocks on a d5 on speed 1.
Don't bother sticking the rad between the 2 GPU's. It will not make any difference but will make the plumbing much more difficult.
i run 980Ti's in SLI and 5930k cooled with 2x 480 rads and 1x 240mm. I have mine on setting 3 but even changing from setting 2 to setting 5 the difference is not noticeable. 1c maybe. D5's have plenty of flow and wouldnt have an issue with what your looking to cool. As noname has stated if i set to setting 1 i will see a couple degrees difference. Noise isnt an issue for me so i keep mine on setting 3.
