Even with VRAM differences you should be able to SLI them
Even with VRAM differences you should be able to SLI them, you only get what the smallest VRAM card has available
Oh and OP I have had a lot of fun on the RSoBB BFBC2 server/s![]()
You can't according to Nvidia.
All the info I've seen of SLI says memory differences are ok though? Not used NV since the 8800GTS though, so haven't kept up tbhCan I mix and match graphics cards with different sizes of memory?
No. For example, an XXXGT 512MB cannot be paired with a XXXGT 1GB in an SLI configuration.
Thats because SLI pretty much locks down which cards you can SLI with what to cards that have the same core revision - which most of the time means the same model. Theres a fairly good reason regarding microstutter why this is done.
Is that current? With the references to xxxGT cards and all
