Would there be much benefit in upgrading?
10 Jul 2008
Huddersfield/ Stokesley
Hi all,
At the moment I have an AMD 64 Athlon 2x 6400+ BE running at GHz. Im wanting to upgrade but my motherboard will on go as high as AM2+ so im kind of stuck with what I can get (I really don't want to upgrade my mobo just yet).
Anyway I was looking at an AMD Phenom X4 9850 2.5GHz and I wondered if it would be worth the upgrade?
Most if not all AM3 cpus are backwards compatible with AM2+
Its down to the mobos cpu support list as to best chip youll be able to stick in
Ah, indeed - it only supports up to Phenom 1 X4.
In that case I can't recommend going for a Phenom 1 X4 - they are slow and hot CPUs.
Unfortunately, that means that upgrading will cost a bit more. What do you use the system for mainly?
Have a look at this review.
For gaming, the Phenom 1 X4 will actually be slower than your current dual core - as the clockspeed is lower and most games don't take advantage of Quad cores - even today.
For editing and mastering music - so long as the applications are multithreaded then the Quad core will be faster. But if the aren't then the dual core will be faster - just like in gaming.
If you want a new CPU that is worth the upgrade - then a Phenom II X4 or i3/i5/i7 would be a big upgrade. If you are on a tight budget - a good AM2+ board like this and an Athlon II X4 would be great, and you could reuse your DDR2 RAM.
Cheers for the help guys. I'll probably wait a while then before upgrading my mother board I've had it now for a year and a half and spent over £100 on it. I want to my use out of it first.
