- 16 Nov 2011
Hey guys.
So i'm not really bothered how tight a fit stuff is in my case, aslong as it doesnt physically bother any other component in my case because of it, but this is my PC
My next step is to be replacing the PSU and motherboard/cpu combination with these two items..
http://www.overclockers.co.uk/showproduct.php?prodid=BU-013-AS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-099-CS
Would this combination fit in my Zalman Z9 case, from what i've seen most motherboards are the same size? Also is that PSU any good, the one i have no w is currently dying so i try to use my pc for a minimum if most.
Also is that cpu/mobo combination any good, i'm going for it as my current motherboard is faulty and i'm using the cpu from the old combination in a new rig for my little brother.
