Was thinking last night of doing a big ish upgrade to my 6yr old one and only computer. But not sure if it will really be worth the hassle.
I only really use it to play wow and browse internet and play music. The spec is this.
Amd Athlon 1GHZ
512mb SD Ram
Gforce4 MX 440 64MB
GA-7IXE4 Motherboard.
wow is ok on low settings but when going into big towns its just a complete freeze. After a day on wow my pc peaks at 600-630mb ram so its paging.
I was thinking two things.
#1 - Just spend £20 on more memory to get 640mb ram to stop paging.
#2 - Buy a cheap motherboard which supports DDR memory and buy1GB of OcUK value DDR Ram. My motherboard atm only supports AGP x2 and im pretty sure my card is AGPX8?. So what id like to know is this.
Would it be worth the hassle to find a socket A, DDR, AGPX8 motherboard or shall i just put a little more ram in it and be done with it? Would i really get that much better performance if i get my card running at AGPX8 speed instead of X2 in WOW?
I've never done anything as big as swap a motherboard and put my old CPU etc onto a new one. Im pretty confident i can do it but it i mess up it will leave me with no computer
So if you think i really wont benefit THAT much then i wont do it. But it the benefit is going to be great then ill give it a go
Cheers, Adam.
Amd Athlon 1GHZ
512mb SD Ram
Gforce4 MX 440 64MB
Cheers, Adam.
New mobo/cpu/ram/grfx card is just me basically building a new comp which i dont really want to do right now
I will be building a new pc later on using AMD64 3700 SD, 2gb Geil Value Ram, ATI Radeon X1800 XT 256MB etc.
