This is a bit like the "use PVA as a sealer" debate, lol.PTFE on the thread is useless, the olive creates the seal.
Speedfit no good if the pipe is not perfectly round, surely?I'd say 99% of ones I come across have been over tightened and the olive has crushed the pipe. You can carefully cut the olive out with a hacksaw and replace to use a new fitting but TBH it isnt worth it, compression fittings are crap. I'd just use a speed fit valve now.
Did you use new olives when you disconnected?, always do with compression fittings they are supposed to be use once.
They are really cheap and a handy thing to have in your spares kit.
If you can find copper ones, they are softer and easier to get a good seal on for diyers since they pinch easier and you can give them a couple of turns and slowly tighten them up after, brass are in the same but I find I get nervous as the effort is higher your worried to damage a pipe
Normally i think by ape armed plumbers or people reusing old olives
Once pipe is damaged its always going to need a lot more effort
And I agree speedfit are generally much easier to use. But they are not perfect, they do not cope at all well with the angle being slightly off
so thats an old olive in there and i never needed to replace that side of the valve olive YET so its been there for about 3/4 years
its just a dislogdged that side when trying to fit the old tap. Olives wise I have like none left I was searching all over the place. I just ordered some brass ones earlier also damn oh well.
Do not use a hacksaw on the pipe.yer i think that might be the case and fearing that right now.
- so whats the solution then cut the pipe off? I dont have a pipe cutter but have a hacksaw. it'll be difficult needs a steady hand id imagine.
speedfit easier to work with but just look rubbish and non symmetrical because the hot water has the compression fittings on it. but if I get really desperate then it'll be the one!
The old JG Speedfit stuff was only guaranteed for 15 years. I think the plastic stuff is really vulnerable to "bad installation" more so than copper just because it is more "attemptable" for DIY'ers. Scratches on the plastic pipe, not cut straight etc, will all contribute to premature failure.You can get some better looking ones but mega £ compared to non speedfit equivalent
They do have one advantage, speed if an issue. Oddly week before last we sprung a leak, went downstairs and found water dripping through ceiling, quickly narrowed it down to bath. Isolated the water and stopped it.
It was a speedfit, been installed since house new about 15 years ago. I checked pipe, 15mm PTFE, ordered a stop end from screwfix and rushed off to get it.
When i got home, disconnected the old one I could see pipe wasnt cut straight. Also disconnecting was a pain, the hot and cold water crossed behind the bath and I suspect now the plumber put them in wrong, had to cut them off and install some extension pipes to fix this issue, which were at an angle and putting pressure on the pipes. Why fail after 15 years? No idea seems very strange, but oddly that morning we had very low water pressure and it was a main being fixed nearby.
I cant see how but wonder if there was some kind of surge that was just enough to dislodge the seal of the fitting after all this time.
Stop end was fine, we are oddly just about to start a new bathroom and I was planning to head off and buy some stop ends for 15mm to cap the pipes whilst working. Ive got 22mm in my spares box, but not 15mm.
The dodgy pipe I will fix when old bath is out, but stopend is fine for now as its not being pushed at an angle its got a good enough seal.
