would this work ok
24 Mar 2007
friend wants a cheap spec pc knocking up.I have made a list of bits but want to check if its ok first.Budget is only £450.O CZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision -Hitachi Deskstar T7K500 500GB SATA-II -Intel Core 2 Quad Pro Q6600 -OcUK GeForce 8600 GT 512MB -Asus P5N-E SLi nForce 650 -Corsair TX 650W ATX2.2 SLi -Thermaltake VA3000BNA Tsunami Dream SuperMidi Aluminium Tower . I have a rewriter and a freezer 7 pro for the cpu.Is there anything i should change or anything i have missed out before i order it.If u could check i would be gratefull .thx
Look's ok to me except one thing.....get a samsung spinpoint h/d...there a lot better h/d's.
but dont listen to me as im just a noob when it come's to pc's.
There are lot's of pc freeks on here that will give you some really good advice.
Corsair TX 650W ATX2.2 SLi Compliant PSU
Asus P5Q Intel P45 (Socket 775) PCI-Express DDR2 Motherboard
Samsung SpinPoint F1 500GB SATA-II 16MB Cache - OEM (HD502IJ)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
OcUK GeForce 8600 GT 512MB DDR2 HDTV/DVI (PCI-Express) - Retail
Thermaltake VA3000BNA Tsunami Dream SuperMidi Aluminium Tower - Black
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz SLI-Ready Edition Dual Channel DDR2 (OCZ2N1066SR2GK)
Does this look a better spec than the one above.Should be ok with this budget.Once again if anything needs changing could u let me know.will be getting it monday.thx
Whats he going to be using it for? Is he going to overclock?
Its a decent spec for the money i was just wondering if he might be better off going for a slightly cheaper mobo and better graphics? 3850pro for example for £58 would be a lot better for gaming (well if Ocuk had stock atm it would be) assuming its going to be used for gaming. Like i said an idea of what it will be used for would be helpful for recommending a spec.
wont be overclocking really.using it mainly for movies,converting and music and surfing on net.gaming is last on the list
