Would this work/what cables?
14 Sep 2011
Another question :p
Ok well, I currently have ATI Radeon HD 6870 and plan on buying 3x BenQ 21.5" LED Monitor
Basically, the gfx card has:
1 Dual Link DVI-I and 1 single link DVI-D
1 HDMI & 2x Mini-DisplayPort
So, for me to link the 3 screens, would I just need 3x this and 1x this for it to work with Eyefinity?
Want to make sure before I buy them to find theres something I missed :P
That would work but you don't need dual link DVI cables for £12 each.
Three single link DVI-D cables for a few pounds each will be fine.
FYI if you plan on gaming at 5760x1080 a single HD 6870 will give pretty poor performance.
Ah, so it is :p I just looked up the cheapest bunch under DVI section of OCUK and it was there :p
With 2x 6870 should gaming be fine with 3 monitors @ 5760x1080? (apparently my mobo is x16 single, x8 dual)
Running at x8/x8 isn't a problem. I imagine the 1GB of VRAM will be the limiting factor at that resolution.
I'm sure the usual suspects can answer that question.
Perhaps you should start a new thread asking for opinions/information on Crossfired HD 6870's at 5760x1080 resolution.
