would this work?
11 Dec 2005
the mighty hereford
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£129.95 £129.95
MB-020-DF DFI Infinity 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-020-DF)
£129.95 £129.95
CA-015-TT Thermaltake VB1000BWS Soprano SuperMidi Tower - Black (CA-015-TT)
£42.95 £42.95
CA-000-TG Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU (CA-000-TG)
£50.50 £50.50
MY-012-GS G.Skill 2GB DDR2 LA PC2-5300 (2x1GB) CAS4 Dual Channel Kit (F2-5400PHU2-2GBLA) (MY-012-GS)
99.99
Subtotal £453.30
VAT £79.33
Total £532.63
hi guys just wondering if i bought this setup would it work in "harmony" together lol. also if there is a better ram or cpu for the money please feel free to put ** opions.
cheerz
john
Don't see why not, though you can never guarantee one component is gonna work with the next one, regardless of wether it meets the spec.
Generally though, the better quality stuff has a higher success rate.
Some manufacterers do compatability tests, not sure if DFI do, but you could have a look.
The case and PSU are fine together.
Pre-Release components will have no info on compatability, one of the problems with being a early adopter.
Personally i buy the bits and plonk em in, if they work.... YIPPEE!!!.... if not, very sad and annoyed gamer.... :(
I find if you buy decent hardware the failure rate is much lower.
