Would you go for .....
25 Mar 2005
Would you go for Akasa Eclipse 62 Aluminium Case & Window £97.41,
or Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case £57.52 + Lian-Li PC-60/PC-7 Window Side Panel - Black £22.27,
almost same price but Akasa does look better IMO,
im gonna get 2xAkasa AK174CB-4BLB 120mm Blue LED Fan anyway and 1xAkasa Dual Blue Cold Cathodes 1 Inverter.
Im looking for easy instalation of all components and also for look of it.
So what do you recon?
Hey mate, I was troubled with the same case issues recently ( thinking of which case to get ) choosing between kandalf/akasa/lian li. From what I gather ( Thanks to the great people here ), both cases are actually good! So it comes down to your personal preference!
true mate,
PC-7 is a great value case and it does come with case fans, but i might go for Eclipse as it looks a bit better imo,
I would go for the Lian Li, I wish I did before but I bought something shoddy instead.
Unfortunately it's like buying a prestige car, if you buy the one that has better looks and better value you still wont be happy (Also, the build quality of Lian Li chassis is legendary).
Just my 2p.
I would go for the PC-7, well thats what i have done!
I think it looks much sleeker. I don't really like windows on pc's. All i want is a smooth discreet looking aluminium box that it quiet and unobtrustive.
I think cases are a very personal thing. Some people want bright lights, windows etc, whereas others want something much more understated.
My advice, chose the one you prefer the look of. They are both pretty easy to install kit in although the asaka is a bit larger.
you all may think im crazy but i dont really need a new case but i do want to learn how to build pc and thats why im gonna buy a new case and then move all components from my current Arctic Cooling Silentium T2 (ok ive got 3 hdd which 2 of them are not fitted properly just lying at the bottom of the case, ive lost my hdd rails, also the rubber bands for the hdd muffler broke and i dont have spare ones left,
i want to add extra light inside so it will look nice - well my first time im gonna build and want to make it look nice, its just some extra 50quid to make it all blue inside :D
i know its a bit of wasting money but its my hard earned money :)
well so thats why im buying a new case,
you all make me (advice :)) buy PC-7 so be it,
REally great case for the money the Pc-7, i've got a black one nad have been very happy with it since I've had it. the 2 x 120 mm fans means it's not too noisey wither, certainly silent enough for me to leave it on over night if I want to download anything :)
