a pair of xfired 5770's for a single GTX460 SE Fermi ?
Given that xfire brings a small amount of problems in itself?
You are getting much better performance with those 5770'sWhat has your experience been like with the two 5770's?
at the moment he is getting around the performace of a 5870, nobody should downgrade from that to a 460, quite a big drop really. crossfire scaling aint that bad on them
Yup, SE is a cut down version mainly for OEM's. You'd be crazy to swap from xfire 5770's.
And let's not forget that the GTX460 'SE' is slower than the standard GTX460.
If it was a swap for a MSI GTX460 Talon Attack or Gigabyte GTX460 SOC card, then it 'might' worth the swap...but since it is not, so no.
