WOW 132 Error - Memory Read Fail
3 Mar 2004
Sheffield
Evening,
Have started getting this stuppid 132 error on WOW every so often on my laptop, have just upgraded from the 2 x 256MB stock RAM to 1GB OCZ stuff, so i thought it was that, but google seems to think different,
Worth trying the stock RAM back in or is it something more than just the RAM?
The same things been happening to me over the last couple of days.
I checked my memory with Vista memory checker, it says all ok.
I guess it could be a driver be it gfx or sound, but I have not updated those in a week or so and all was well up until yesterday....
Been running it on PC and laptop in sync for about 16 hours over last 4 days, installed the new RAM this morning and had about 4 hours on it then and all was fine, put it on tonight and the laptop has popped the error up twice.
Thinking this is something blizzards end having read a few forums from google about it
Really would not surprise me.....
Got me worried though, spend £30 on 1GB of RAM for this to happen nearly straight away :p
WIll try and run the error program on the blizz site see if it brings anything up, other wise will have to put up with it for a day of two see if anything is resolved
Just had another search on google, and found 3 people who had this problem on the 30th august this year...definatly seems to be soemthing to do at blizzards end tbh, which is poo :(
I was getting error #134, which is basically a rebadged version of #132 apparently, spent weeks testing hardware and running stability tests, but the error kept coming.
Now comes the funny part, after all of this, there was a LOT of people on the forums with this same problem, all had found no problems with their hardware. One person found the solution to the majority of peoples problem. AVG antivirus. I have no idea why, and I don't like the solution, but un-installing AVG stopped the errors.
Just though I'd post incase it helps. Basically, the errors aren't always hardware based.
Are you using any Addons?
i had this error and it would re-appear when I was trying to get the Zeppelin from orgrimmar to go to Grom Gol. Soon as it switched to Grom Gol it would freak out and give the error message above. It would repeat until the Zeppelin returned to Orgrimmar and then the game would stop crashing and let me in.
Only when I disabled all of my addons did it then allow me to travel to Grom Gol.
At a guess it could be a conflict with some Ace2 addons due to Internal/External libaries.
Then again it could be something completely different, but disable all addons for a while or redownload them from scratch.
because of really bad FPS on my laptop ( i mean like 20 with EVERYTHING turned to lowest ) the only addons i have put on for my GF are questhelper, oglow and auctioneer. We only ever play these characters together anyways so i can just shout stuff at her :p
Did seem to play fine last night though for a couple of hours, going to be hitting it again today trying to get some boosts through some of the lwoer instances any ways so will see if it behaves itself
Questhelper was one of the addons I had enabled when mine was crashing. I've also disabled it on my characters as it was causing Frames per second problems.
As an alternative I'd suggest using Tourguide or Carbonite and see how it goes with those enabled.
But i'm thinking it is questhelper causing the problems.
Right its done it about 4 times in 40 minutes now and has just reset my laptop :( stupid bloody thing! would do now ive just bought the game again and everything wouldnt it :(
Got rid of all addons and it still did it, gonna try to put the old RAM back in, if it works without this new stuff dunno what im gonna do with the 1GB i just bought i cant really send it back as its already been used
