WoW - Best UI
Man of Honour
29 Jun 2004
Oxfordshire
Hey guys
i've just got back into WoW again
and i wanna know what the best UI is, i heard its Cosmos but figured i'd get the best opinion from you lot as quite a few people on here play it
So which do you use?
Im a warrior by the way if that helps to choose one
nurfed is a good start, but nothing beats making your own ui, only you know what exactly you want, using a premade one might have a lot of stuff you want missing or too much crap in it for you :eek: i use my own, only part of nurfed i use is the ABinfo mod, the flash on cooldowns is great :D rest of the stuff i use i got from curse and worldofwar.net :)
I've installed Cosmos over the weekend and all is fine BUT the armour dmg diagram on the right hand side of the screen has been pushed off the screen and only shows one arm and the sword. Tried different screen resolutions but same problem. Anyone had this or know how to sort it out?
Thanks
I use quite a few :
CombatScrollingText
NerfedUI
Auctioneer
Accountant
TitanPanel (although the most recent one seems to be bugged, putting a bar at the top and the bottom... annoying)
ct_raid for mc, ony and ZulG
decursive
