wow help (again)
5 Aug 2006
Derbyshire
hey all.
I am on a pvp server and a level 70 hunter but am quite n00bish still. I am half epic with gladiator gear set 1, my hp is 11.3k but AP only 1250 and I am BM spec but think I need to go MM spec
what is the best talent spec for hunter?
could you post a screenie of the wowhead talent thing
Heres the link
http://www.wowhead.com/?talent=c
For PvP or PvE? Arena sets aren't made for high damage, but for survival. That's why your AP is so low.
Can't really be any more helpful unless we know what you want to be using it for.
You could change you gems to AP gems, would boost your over AP.
I think you need to choose between arena and battlegrounds, since there are specs for both areas.
I think BM is the arena spec, its the best single target dps.
As for battlegrounds i think marksman is better.
But again, im not sure.
i would have thought that survival/bm for arena and them mm with some points in bm for battlegrounds.
here, ill make some up :)... bare in mind, i gave up on my hunter LONGGGG ago, now playing rogue, just got back into wow as well.
MM build
BM build
ags
hmmmm/ might go with the MM as there is a trinket that can get me out of all stuns etc etc so is sort of like beastal wrath anyway.
If my warrior was on you wont last a second without a good bm/survival spec.
The harded huters in bg and arena are the ones who are survival and bm speced
