Only way to describe what I feel.
I sent overclockers my gfx card that had issues, documented on this forum, other users confirmed they also had these issues and a quick google search will also verify the claims.
My MSI Lightning card has issues. I explained the precise problem in two paragraphs I wrote to overclockers sent with my Lightning gfx card. I precisely described the problem never once mentioning the card was artifacting or causing other issues under load. I specifically explained that the problems were occurring exactly while NOT playing any games.
However this is the response I got for the RMA being rejected.
"Intensive Stress Test under multiple benchmarks - no corruptions - no fault found"
I have just received the package and havent a clue what to do. I will when I get back from work tomorrow install the card and see if magically the problem has disappeared otherwise I have to go through the trouble of sending the card back paying again £8.
What a waste of time. Didnt expect this from overclockers.
Update 14 April 2014 - SO - the i've narrowed it down to the Display Port port. This is the issue I believe, I've since disconnected my monitor cable from the gfx card and my tv is fine and no longer tearing/flickering. Read the rest of the post for context.
