So which is likely to be better, all other things being equal such as panel type, contrast, response, and let's assume price isn't a factor?
From my perspective it's about gaming, and mainly FPS stuff (Battlefield 4, etc). Of course if you were simply editing photos the 60Hz v 144Hz isn't going to be as relevant as you aren't dealing with loads of fast changes tot he image.
Let us assume we have a good TN panel. But would an IPS panel change the answer?
Is the extra detail of the 4k monitor that can only refresh at 60Hz, superior to the better refresh rate of a WQHD (2560x1440) monitor that could do 144Hz? Let us assume we have a GPU(s) that can handle the 144Hz frame rate, at the lower resolution or only the 60Hz at the higher resolution.
Now what about if we throw G-sync into the mix because our GPU isn't quite as powerful and can't quite do the frame rate? If that is reducing any tearing or stuttering of image effect, is that going to negate a difference between 60Hz and 144Hz?
And being bluntly honest, if you are sitting only 4' from a 27" type screen can your less than 20-20 vision actually see a difference between WQHD and UHD? Would any of these opinions change if the screen was bigger, say the 34" curved monitors we start to see?
