Wraith Prism RGB Cooler
18 Oct 2002
Chaps, today I will have my Ryzen 7 3700X, and can I confirm all I need to plug in the motherboard is the CPU fan and the USB connection please, and not both extra leads that come with it.
Thank you.
Thank you.
Yes you just need to plug in the USB lead not the other one.
It is a awful cable to try and hide - any ideas chaps. I have wrapped most of it around the CPU cooler but it runs down past under the the GPU to the bottom of the mobo.
The USB cable allows you to fully control the ARGB in all 3 zones, but you have to use the Coolermaster software to so it, it doesn't hook into any other vendor's RGB suite.
