Just waiting for the lat couple of bits for my first build to arrive and I've suddenly had a bit of nerves regarding the CPU cooler. I know that the Ryzen 2 chips can get quite hot and that the 2600x has a good auto overclock with it's Precision 2 boost. Looking at some reviews of the included Wraith Spire it seems like it's an ok cooler, and better than the stock intel ones, but is bettered by almost any other alternative. It's also confusing as there seem to be two versions of the Spire (Ryzen 1 vs 2's versions).
I don't plan to do any manual overclocking, but I intend to keep the system for a while so that might change. With the auto overclock on the 2600x would I be better off doing a minor cooling upgrade?
I'm at my budget's end but was considering whether I should be grabbing the Cryorig H7 or the CM Hyper 212 Evo as a sensible budget option to shave what looks to be around 10 degrees off operating temperatures with stock settings.
