wraith spire(RGB) vs prism
Permabanned
11 Jan 2019
bedlam
SO how much better is a prism over a wraith spire
My pc caes is limited to a 92mm cpu cooler and i do like a bit of RGB(Mainly the R) and most if not all 92mm fans have no LED or any type
right now i have an wraith spire(RGB) and it dose a fantastic job of cooling the 1700 @ 3.75 all core.51c gaming(i cant get more out of it(bad chip)) but i am picking up a 3600 or 3700 on payday and i dont know id the wraith spire will be upto the job of pushing the chips and over long gaming sessions.
would picking up a prism give me much better cooling power
The 3700x comes with the prism cooler so I'd use that over the spire mate the prism also comes with the 3900x aswell
I have a prism on my 3600 with a 4.2 all core OC and I never see above 67c in stress tests and that's with the low switch setting so apparently limits the fan speed to 2750rpm as opposed to 3650 for high, gaming is around 50c with idle at 32c.
So I'd get the prism mate its a good little cooler but it can be noisey just so your aware it will cool the 3600 processor very well
