Write-Protection?!
16 Apr 2007
UK
Hey all,
I got a little problem on my hands...
I went to go into a folder in my hard drive and I accidently moved it into a folder named:
"bf321f6c207fc7b5815bd93f94d6082b"
I think it has something to do with the Microsoft Update or something
Anyways, the bigger problem is when I go to move it back into my hard drive I get the following message:
"Cannot create or replace docs: Access is denied.
Make sure the disc is not full or write-protected and that the file is not currently in use."
I get this message if I try to undo the move and when I try to double click and access it.
The disc is far from full, nor is it writeprotected and the folder isn't in use. Another thing is when I right click and click properties it says the folder size is 0 bytes :\
Any help in retrieving my work will be greatly appreciated!
Thanks,
Marky
Rivey said:
Boot into safe mode and see if you can move it.
Heh just before you said that I got the same idea, and was able to change the permissions and to access the folder :)
- Marky
