I recently created a question on Programmers stackexchange about creating tests for legacy code prior to a refactor/redesign of a code base.
As stackexchange doesn't particularly allow a forum type conversation I thought I'd allow it to continue here, highlighting a few answers/comment that stuck out for me and my thoughts
A lot of answers boil down to testing at the right level i.e. integration testing instead of unit testing.
I think this point is something I may have to accept in my case as the interface between the DAO and the Service WILL change. i.e. the DAO interface goes from
to
I think this point is further highlighted by this answer
This assumed to some degree that the interface to the DAO remained the same.
Then there's this answer
At the moment I'm tempted to adopt this approach, i.e. refactor/redesign the tests along with the code itself (seeing as the interface between the components is not going to remain the same)
And then there's a comment which goes even further
At first I read that as "Don't write integration tests..... Only unit test the new classes". Now I realise this was actually "Don't write unit tests, write integration tests, only write unit tests for new classes"
But again because the interface between the layers that I would be doing the integration testing on is changing I come back to one of the first points I highlighted.
Thoughts?
NB: I gave the example of a service layer interacting with a DAO and the service layer dealing with the DataResultSet, in reality it's worse than that as it's a JSF bean (i.e. View/Controller code) that has data access type code mixed in with it
I've read some answers to questions along a similar line such as "How do you keep your unit tests working when refactoring?". In my case the scenario is slightly different in that I've been given a project to review and bring in line with some standards we have, currently there are no tests at all for the project!
I've identified a number of things I think could have been done better such as NOT mixing DAO type code in a service layer.
Before refactoring it seemed like a good idea to write tests for the existing code. The problem it appears to me is that when I do refactor then those tests will break as I'm changing where certain logic is done and the tests will be written with the previous structure in mind (mocked dependencies etc.)
In my case, what would be the best way to procede? I'm tempted to write the tests around the refactored code but I'm aware there is a risk I may refactor things incorrectly that could change the desired behaviour.
Whether this is a refactor or a redesign I'm happy for my understanding of those terms to be corrected, currently I'm working on the following definition for refactoring "With refactoring, by definition, you don't change what your software does, you change how it does it.". So I'm not changing what the software does I'd be changing how/where it does it.
Equally I can see the argument that if I'm changing the signature of methods that could be considered a redesign.
Here's a brief example
MyDocumentService.java (current)
Code:public class MyDocumentService { ... public List<Document> findAllDocuments() { DataResultSet rs = documentDAO.findAllDocuments(); List<Document> documents = new ArrayList<>(); for(DataObject do: rs.getRows()) { //get row data create new document add it to //documents list } return documents; } }
MyDocumentService.java (refactored/redesigned whatever)
Code:public class MyDocumentService { ... public List<Document> findAllDocuments() { //Code dealing with DataResultSet moved back up to DAO //DAO now returns a List<Document> instead of a DataResultSet return documentDAO.findAllDocuments(); } }
You're looking for tests that check for regressions. i.e. breaking some existing behaviour. I would start by identifying at what level that behaviour will remain the same, and that the interface driving that behaviour will remain the same, and start putting in tests at that point.
You now have some tests that will assert that whatever you do below this level, your behaviour remains the same.
You're quite right to question how the tests and code can remain in sync. If your interface to a component remains the same, then you can write a test around this and assert the same conditions for both implementations (as you create the new implementation). If it doesn't, then you have to accept that a test for a redundant component is a redundant test.
Code:
DataResultSet findAllDocuments()
to
Code:
Don't write strict unit tests where you mock all the dependencies. Some people will tell you these aren't real unit tests. Ignore them. These tests are useful, and that's what matters.
Let's look at your example:
Your test probably looks something like this:
Code:DocumentDao documentDao = Mock.create(DocumentDao.class); Mock.when(documentDao.findAllDocuments()) .thenReturn(DataResultSet.create(...)) assertEquals(..., new MyDocumentService(documentDao).findAllDocuments());
Instead of mocking DocumentDao, mock its dependencies:
Code:DocumentDao documentDao = new DocumentDao(db); Mock.when(db...) .thenReturn(...) assertEquals(..., new MyDocumentService(documentDao).findAllDocuments());
Now, you can move logic from MyDocumentService into DocumentDao without the tests breaking. The tests will show that the functionality is the same (so far as you've tested it).
I suggest - if you haven't already - reading both Working Effectively With Legacy Code as well as Refactoring - Improving the Design of Existing Code.
I don't necessarily see this as a problem: Write the tests, change the structure of your code, and then adjust the test structure also. This will give you direct feedback whether your new structure is actually better than the old one, because if it is, the adjusted tests will be easier to write (and thus changing the tests should be relatively straightforward, lowering the risk of having a newly introduced bug pass the tests).
Also, as others have already written: Don't write too detailed tests (at least not at the beginning). Try to stay at a high level of abstraction (thus your tests will probably better characterized as regression or even integration tests).
Don't, write integration tests. The "refactoring" you are planning is above the level of unit testing. Only unit test the new classes (or the old ones one you know you're keeping them).
Thoughts?
