Hi,
I recently purchased some new ram as the old stuff died.
I got these: OCZ Platinum Series 4GB (2x2GB) PC2-8500C5 1066MHz Dual Channel.
I tried looking in cpu-z first of all, and the result showed that they are just PC2-6400 ?!
I also tried just now overclocking in the bios, 3.6ghz worked fine. As soon as I upped it to 4ghz (which I thought with the new ram it would handle fine) the Bios didn't load and Windows had been reset.
Voltage I used for cpu was 1.27
thanks,
thanks,
