- 18 Oct 2002
- Glasgow
Guys,
Looking for some help/advice.
I think my WRT54G running Tomato 1.28 is on the way out, it has started intermittantly loosing its internet connection and needs rebooted to gain functionality.
It provides internet connectivity to my parents house 4 doors down using the WDS function within the Tomato 1.28 firmware.
Is there a newer router available that can run a similar firmware and still provide connectivity to the WRT54G down the road, the parents use theirs very little so would not be looking to upgrade this unit.
I suppose, the free version would be to swap routers but then I would receive calls ocassionally having to get them to reboot before they can check their emails.
Thanks
Thanks
