- 6 Dec 2002
- Belfast
I set up my new Linksys WRT54GS router (with my NTL cable connection) last night with no difficulty whatsoever. However, this evening when I came in from work I fired up the laptop and proceeded to connected via the wireless connection. This proved to be very unstable and frequently I would get the 'The connection was reset' message in Firefox. The same thing happened in IE.
I then turned on my desktop (which is connected to the router via Cat5) and the same problem is happening with it.
When I ping 'news.bbc.co.uk' I get this:
Any ideas?
Code:
C:\Documents and Settings\admin>ping -t news.bbc.co.uk
Pinging newswww.bbc.net.uk [212.58.226.19] with 32 bytes of dat
Reply from 212.58.226.19: bytes=32 time=34ms TTL=53
Reply from 212.58.226.19: bytes=32 time=24ms TTL=53
Reply from 212.58.226.19: bytes=32 time=51ms TTL=53
Reply from 212.58.226.19: bytes=32 time=23ms TTL=53
Reply from 212.58.226.19: bytes=32 time=31ms TTL=53
Reply from 212.58.226.19: bytes=32 time=22ms TTL=53
Request timed out.
Reply from 212.58.226.19: bytes=32 time=57ms TTL=53
Request timed out.
Reply from 212.58.226.19: bytes=32 time=46ms TTL=53
Reply from 212.58.226.19: bytes=32 time=25ms TTL=53
Reply from 212.58.226.19: bytes=32 time=44ms TTL=53
Reply from 212.58.226.19: bytes=32 time=27ms TTL=53
Request timed out.
Ping statistics for 212.58.226.19:
Packets: Sent = 31, Received = 28, Lost = 3 (9% loss),
Approximate round trip times in milli-seconds:
Minimum = 22ms, Maximum = 57ms, Average = 28ms
Control-C
^C
Any ideas?
