WSVGA Screen Question
3 Jul 2009
Hi, I wonder if anyone can help me?? I've just bought a Dell Inspiron Mini 10V netbook for my daughter and I've been having a couple of issues with the WSVGA screen resolution in Windows XP Service Pack 3. For those who don't know WSVGA has a max resolution of 1024x600 which is the cause of my problem.
Some applications have fixed size windows, i.e. you can not resize them to suit your needs. There are some programs that we have been trying to use where the bottom part of the application window is off the bottom of the screen, as such you cannot access the OK, Cancel and any other options or buttons that are down there. I have got the WinXP task bar on auto hide and even that isn't enough.
Any ideas on how to get around this????
