WTF to do ?!?!!?!?
12 Jun 2007
Ireland
well basically i have hd2900xt 1 gig ddr4 it works fine on any game but when it comes to cs:s (counter strike source) it works fine for a moment and then suddenly it drops to 30 fps and i lag hen goes up and drops again then it goes back up to 200 + if anyone has these problem come forward PS : (it never done this before just last 3 weeks it kept doing that but in all other games its fine )
if not recommend me the best 8800 gts or it does not matter witch one you get you can up the clocks on anyone ? im planing to water cool it so it would be better that it had warranty if remove stock cooler.
Thank you all for helping ;)
edit : i play and run cs:s clan so i need it to work perfectly other game it does not matter for me at the moment
why gt/gtx not gts ?:confused:
GTS doesn't give good enough performance increase over the GT to warrant the extra £££, the GTX, being a few quid more than the new GTS, is more worth your cash than the new GTS (assuming you game at a sufficiently high resolution).
