- 27 Jul 2006
- Huddersfield
Right, i have Virgin Broadband through the modem they give you. I have no router.
I assumed that i could just unplug the ethernet cable from the PC and plug it in the 360. This is not the case.
Says there are problems with the connection. I run the test and it stops at the IP Address stage.
Can anyone offer advice on how i can make this work.
Also what is the cheapest solution to have both pluged in at the same time as i did with my ADSL router.
Now im on cable for somereason my brain isnt working as well.
Thanks
Zero.
Thanks
Zero.
lol
